Текущее время: 25 окт 2026, 14:40
 Заголовок сообщения: GSM шлюз
СообщениеДобавлено: 22 ноя 2008, 11:12
Купил шлюз Smartcell 111L, подключил к CO, настроил СО, LCR пока не переписывал.
Назначил пока транки на кнопки системника.
1. При звонке на мобиль, если ответить на звонок а потом "положить трубку", то СО-шка нормально отпадывает.
2. Если при звонке на мобиль сигнал занято или нажать "отбой" (на мобиле) то СО-шка не отбивается.
В мануале от шлюза есть упоминание про тоны... Call Progress tones
Type ON cadence OFF cadence Remarks
Dial tone Continuous
Busy tone 0.5 Sec 0.5 Sec
Error tone 0.2 Sec 0.2 Sec
Distinctive
tone 0.2 Sec 0.1 Sec Incoming ring in off-hook,
before dialling started
Confirmation
tone
(for
programming)0.4 Sec 0.1 Sec 3 beeps
Rejection
tone
(for
programming)0.4 Sec 0.1 Sec 2 beeps
Есть...
4.9 Set Reverse Polarity Signaling Method
4.9.1 Feature description
If the PABX trunk connected to the unit supports Reverse Polarity signalling method, you should use this command to set the unit to Reverse Polarity signalling mode.
4.9.2 Feature Programming
Dial **1343**# [hear a confirmation tone] to enter programming mode.
Dial *7610*# [hear a confirmation tone].
4.10 Set Pulse Drop Signaling Method
4.10.1 Feature description
If the PABX trunk connected to the unit supports Pulse Drop signalling method, you should use this command to set the unit to Pulse Drop signalling mode.
4.10.2 Feature Programming
Dial *7620*# [hear a confirmation tone].
4.11 Set Pulse Drop Width
4.11.1 Feature description
If Pulse Drop signalling method is used, the width of the pulse can be controlled using this command. In general the pulse width MUST be higher than the parameter used by the PABX in order to be recognized by it (e.g. if the PABX trunk is set to a pulse drop of 1 second then the pulse of the unit should be set to 1.5 seconds). The pulse width is referred to by units of 100 milliseconds and can be anything between 100 ms and 9900 ms (99 units).
I.E.: to set the pulse width to 2 seconds (2000 ms), 20 should be programmed.
The default value for the pulse width is: 1.5 second (15 in the programming mode).
4.11.2 Feature Programming
Dial *7630*# [hear a confirmation tone].
Dial 1 or 2 digits to set the desired width (100 ms to 9900 ms).
Example: to set the pulse drop width to 2 seconds dial *7630*# [hear a confirmation tone] 20# [hear a confirmation
Что можно сделать (не покупая внеш. отбойники) чтобы при всяком раскладе СО-шка нормально отбивалась?
Поиск глядел по "отбойник" ничего не нашел... :(
быть может в CM3204>1 поможет?
Военная мудрость.
 Заголовок сообщения: Re: GSM шлюз
СообщениеДобавлено: 24 ноя 2008, 06:36
А где вы нашли такую команду???
СообщениеДобавлено: 24 ноя 2008, 09:30
Гы... I'm sorry.... I'm crazy...
CM3504.....
:lol:
Военная мудрость.
СообщениеДобавлено: 26 ноя 2008, 17:29
Все прописал все робит.. НО...
в LCR в самом конце, там где пишется, 1-st choise, 2-nd choise...
во 2-м написал основной, потоковый, а он блин нифига...
т.е. в случае занятости транков СО, вызов должен идти через другое направление... а не идет...
Военная мудрость.
СообщениеДобавлено: 27 ноя 2008, 21:03
Ну блин, должно-же робить... мож где галочку забыл поставитььь...???
Военная мудрость.
СообщениеДобавлено: 09 дек 2008, 07:07
Не идет? Или идет но не дозваниваешься, например, потому что номер неправильно набирается?
СообщениеДобавлено: 09 дек 2008, 09:54
Номер набирается правильно... но если обе линии заняты, то получаю сигнал типа занятости...
Военная мудрость.
СообщениеДобавлено: 12 мар 2009, 17:02
Насколько возможно сделать переадресацию на самом транке?
т.е. секретарша звонить с этого транка(т.е. мобильника) и хочет сделать трансфер на еще куданибуть. Будет-ли работать так как это происходит если у тебя мобильник в руке?
Обычно занимается 2 транка (т.е. трансфер происходит не на самом шлюзе а на станции).
Возможно-ли получить "АОН" с ГСМ шлюза на системник? Чего нада для этого?
Военная мудрость.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 11
