Текущее время: 27 июн 2026, 18:33
 Заголовок сообщения: Neax 2000 + Cisco
СообщениеДобавлено: 29 ноя 2016, 18:30
Добрый день.
Столкнулся с трудностью подключения атс Neax 2000 с Cisco маршрутизатором.
Есть плата SPN-DTA(PRT)-A (AP 05) уже работает, добавил плату NEC SPN-30PRTA-B (AP04) и настроил аналогично. Все переключатели как на первой в плане настроек.
Конфиг выглядит так:
"050","04","12","","30PRTA"
"050","05","12","","30PRTA"
"051","04","0","","Use Expanded AP Highway channel 128 time slots"
"051","05","0","","Use Expanded AP Highway channel 128 time slots"
"0701","0401","D100","",""
"0701","0402","D101","",""
"0701","0403","D102","",""
"0701","0404","D103","",""
"0701","0405","D104","",""
"0701","0406","D105","",""
"0701","0407","D106","",""
"0701","0408","D107","",""
"0701","0409","D108","",""
"0701","0410","D109","",""
"0701","0411","D110","",""
"0701","0412","D111","",""
"0701","0413","D102","",""
"0701","0414","D113","",""
"0701","0415","D114","",""
"0701","0416","D115","",""
"0701","0417","D116","",""
"0701","0418","D117","",""
"0701","0419","D118","",""
"0701","0420","D119","",""
"0701","0421","D120","",""
"0701","0422","D121","",""
"0701","0423","D122","",""
"0701","0424","D123","",""
"0701","0425","D124","",""
"0701","0426","D125","",""
"0701","0427","D126","",""
"0701","0428","D127","",""
"0701","0429","D128","",""
"0701","0430","D129","",""
"0701","0431","D130","",""
"0701","0501","D030","",""
"0701","0502","D031","",""
"0701","0503","D032","",""
"0701","0504","D033","",""
"0701","0505","D034","",""
"0701","0506","D035","",""
"0701","0507","D036","",""
"0701","0508","D037","",""
"0701","0509","D038","",""
"0701","0510","D039","",""
"0701","0511","D040","",""
"0701","0512","D041","",""
"0701","0513","D042","",""
"0701","0514","D043","",""
"0701","0515","D044","",""
"0701","0516","D045","",""
"0701","0517","D046","",""
"0701","0518","D047","",""
"0701","0519","D048","",""
"0701","0520","D049","",""
"0701","0521","D050","",""
"0701","0522","D051","",""
"0701","0523","D052","",""
"0701","0524","D053","",""
"0701","0525","D054","",""
"0701","0526","D055","",""
"0701","0527","D056","",""
"0701","0528","D057","",""
"0701","0529","D058","",""
"0701","0530","D059","",""
"0701","0531","D060","",""
"AA15","04","0","","30 PRI"
"AA15","05","0","","30 PRI"
"AA14","04","0","","30 PRI"
"AA14","05","0","","30 PRI"
"AA06","04","24","","EDSS1"
"AA06","05","24","","EDSS1"
"0608","1","04","","D"
"0608","0","05","","D"
"A900","0","045","","B to D"
"A900","1","115","","B to D"
"3000","100","10","",""
"3000","101","10","",""
"3000","102","10","",""
"3000","103","10","",""
"3000","104","10","",""
"3000","105","10","",""
"3000","106","10","",""
"3000","107","10","",""
"3000","108","10","",""
"3000","109","10","",""
"3000","110","10","",""
"3000","111","10","",""
"3000","112","10","",""
"3000","113","10","",""
"3000","114","10","",""
"3000","115","11","",""
"3000","116","10","",""
"3000","117","10","",""
"3000","118","10","",""
"3000","119","10","",""
"3000","120","10","",""
"3000","121","10","",""
"3000","122","10","",""
"3000","123","10","",""
"3000","124","10","",""
"3000","125","10","",""
"3000","126","10","",""
"3000","127","10","",""
"3000","128","10","",""
"3000","129","10","",""
"3000","130","10","",""
Для 030-044 08, 045 09, 045-060 08
"3007","100","000","",""
"3007","101","001","",""
"3007","102","002","",""
"3007","103","003","",""
"3007","104","004","",""
"3007","105","005","",""
"3007","106","006","",""
"3007","107","007","",""
"3007","108","008","",""
"3007","109","009","",""
"3007","110","010","",""
"3007","111","011","",""
"3007","112","012","",""
"3007","104","013","",""
"3007","114","014","",""
"3007","115","NONE","",""
"3007","116","015","",""
"3007","117","016","",""
"3007","118","017","",""
"3007","119","018","",""
"3007","120","019","",""
"3007","121","020","",""
"3007","122","021","",""
"3007","123","022","",""
"3007","124","023","",""
"3007","125","024","",""
"3007","126","025","",""
"3007","127","026","",""
"3007","128","027","",""
"3007","129","028","",""
"3007","130","029","",""
Для 030-060 030-059 в 045 NONE
Далее 10 настроена 1 в 1 с 08, а 11 1 в 1 с 09
Только
"3593","04","01","","ISDN Dch controller"
"3593","05","00","","ISDN Dch controller"
В роут паттерне добавил к первому 08 транк роуту 10 вторым.
Отключаю провод 05 от маршрутизатора и подключаю провод от 04. Ошибок нет. Все показатели в норме. Но звонок не проходит в обе стороны.
Подскажите где еще посмотреть.
 Заголовок сообщения: Re: Neax 2000 + Cisco
СообщениеДобавлено: 30 ноя 2016, 12:20
У вас CICи не правильно прописаны для нового потока (AP04 транки с 030-060) в команде 3007. Они должны нумероваться с 000 по 029, кроме D-канала
СообщениеДобавлено: 30 ноя 2016, 13:09
CIC то как раз похоже правильно присвоены.
Не нравится:
1.
Как минимум синхронизация должна стоять по-другому.
2.
Зачем? Сколько потоковых плат в станции? Почему сначала не использовать Basic?
3. Где СМ3002, 3500, 3504, 3509, 3516, 3528, 3589, 3590?
Половины не написАли...
СообщениеДобавлено: 30 ноя 2016, 16:50
Спасибо за ответы.
Точно в CIC нет проблем? Я не успел разобраться для чего вообще это сопоставление.
Все остальные настройки одинаковы с корректно настроенным 05 AP и 08 транком.
Попробую разобраться с переключателями на плате. Можете пояснить какую синхронизацию вы имеете в виду?
Рассуждая логически я в 3000 программе могу задать D каналам 08 транк как и на работающей плате... попробовал, но не помогло.
СообщениеДобавлено: 30 ноя 2016, 17:17
Если Ваши настройки:
то тут прописано правильно.
Если бы все были одинаковы там, где надо, оно бы и работало.
Нижние два флажка на piano key switch. Синхронизация берется от какого-то одного потока. На второй карте она должна быть выставлена как вторичная. На третьей (если таковая есть) вообще выключена.
СообщениеДобавлено: 01 дек 2016, 10:45
На 05 рабочей 2-1 стоит в OFF 2-2 стоит в ON.
На 04 которую подключаю тоже стояло так же, поменял 1 в ON и 2 в OFF перезагрузил АТС и не помогло.
При дебаге со стороны Cisco при звонке выдает как будто звонок отправляется в поток, но в несуществующие D каналы на АТС. Пытается по каналу 1 пройти звонок. При этом если менять поток на рабочий, то по первому каналу звонок проходит.
Получается на 05 AP первый канал есть, а на 04 его нет.
СообщениеДобавлено: 01 дек 2016, 23:01
Тут, на форуме, попадаются сценарии полного программирования потока ISDN PRI. Я и сам когда-то выкладывал. Пройдитесь по командам внимательно. Где-то у Вас ошибка.
СообщениеДобавлено: 02 дек 2016, 11:14
Пробовал и по скриптам что на форуме программировать и по мануалу программирования ISDN System Manual.
СообщениеДобавлено: 13 фев 2017, 09:22
У Вас D-канал на новой плате поднимается?
Сейчас этот форум просматривают: Bing [Bot] и гости: 12
