Текущее время: 13 июн 2026, 20:50
 Заголовок сообщения: Не поднимается поток E1
СообщениеДобавлено: 21 окт 2014, 12:21
Хочу соединить две АТС Neax2000IPS по CCIS. Обе станции состоят из одного PIMa. Конфигурация у АТС одинаковая: LT0-8DLCP, LT1-LT4-8LCAA, LT08-30DTC, LT09-SC00, MP-CP24B. На обоих процессорах была произведена полная очистка (режим "B"). На плате 30DTC выставлены перемычки для 120 ОМ, симм., на SW: 1 и 8 в ON, остальные в OFF. На другой АТС на 30DTC все перемычки также, кроме SW 1 в OFF. На SC00 на SW0: 1-3 в OFF, 4 в ON. На CP24B и там и там SW2: 1-3 в ON, 2 в OFF. На 30DTC с обоих сторон выставлены AP4 (свич в 4 положение), на SC00 - AP5 (свич в 5 положение). На одной станции был залит скрипт:
"050","04","09","","Propisyvanie karty 30DTC"
"050","05","11","","Propisyvanie karty SC00"
"0701","0401","D101","",""
"0701","0402","D102","",""
"0701","0403","D103","",""
"0701","0404","D104","",""
"0701","0405","D105","",""
"0701","0406","D106","",""
"0701","0407","D107","",""
"0701","0408","D108","",""
"0701","0409","D109","",""
"0701","0410","D110","",""
"0701","0411","D111","",""
"0701","0412","D112","",""
"0701","0413","D113","",""
"0701","0414","D114","",""
"0701","0415","D115","",""
"0701","0416","D100","","D-chanel"
"0701","0417","D116","",""
"0701","0418","D117","",""
"0701","0419","D118","",""
"0701","0420","D119","",""
"0701","0421","D120","",""
"0701","0422","D121","",""
"0701","0423","D122","",""
"0701","0424","D123","",""
"0701","0425","D124","",""
"0701","0426","D125","",""
"0701","0427","D126","",""
"0701","0428","D127","",""
"0701","0429","D128","",""
"0701","0430","D129","",""
"0701","0431","D130","",""
"3000","101","30","","Route - 07 (golosovoi Route)"
"3000","102","30","",""
"3000","103","30","",""
"3000","104","30","",""
"3000","105","30","",""
"3000","106","30","",""
"3000","107","30","",""
"3000","108","30","",""
"3000","109","30","",""
"3000","110","30","",""
"3000","111","30","",""
"3000","112","30","",""
"3000","113","30","",""
"3000","114","30","",""
"3000","115","30","",""
"3000","116","30","",""
"3000","117","30","",""
"3000","118","30","",""
"3000","119","30","",""
"3000","120","30","",""
"3000","121","30","",""
"3000","122","30","",""
"3000","123","30","",""
"3000","124","30","",""
"3000","125","30","",""
"3000","126","30","",""
"3000","127","30","",""
"3000","128","30","",""
"3000","129","30","",""
"3000","130","30","",""
"3000","100","31","","(D-ch. Route)"
"3500","30","04","",""
"3500","31","04","",""
"3501","30","7","",""
"3502","30","3","",""
"3504","30","2","",""
"3504","31","2","",""
"3505","30","1","",""
"3505","31","1","",""
"3509","30","03","",""
"3519","30","7","",""
"3520","30","00","",""
"3589","30","0","","CRC on"
"3590","30","0","",""
"3590","31","0","",""
"3591","30","0","","Common Channel Number"
"3591","31","0","",""
"3035","101","001","",""
"3035","102","002","",""
"3035","103","003","",""
"3035","104","004","",""
"3035","105","005","",""
"3035","106","006","",""
"3035","107","007","",""
"3035","108","008","",""
"3035","109","009","",""
"3035","110","010","",""
"3035","111","011","",""
"3035","112","012","",""
"3035","113","013","",""
"3035","114","014","",""
"3035","115","015","",""
"3035","116","016","",""
"3035","117","017","",""
"3035","118","018","",""
"3035","119","019","",""
"3035","120","020","",""
"3035","121","021","",""
"3035","122","022","",""
"3035","123","023","",""
"3035","124","024","",""
"3035","125","025","",""
"3035","126","026","",""
"3035","127","027","",""
"3035","128","028","",""
"3035","129","029","",""
"3035","130","030","",""
"0607","0","05","",""
"A700","0","100","",""
"A726","0","0","","Calling Name"
"08","255","1","","---"
"08","379","0","","---"
"A728","0","0","","Transferring"
"A701","0","00228","","OPC"
"A702","0","00232","","DPC"
"A703","0","0","","billing"
"A704","0","00232","","---"
"A705","0","00232","","fault report"
"A8","00232","0","","CCIS routing label"
"310","0","04","","country"
"08","253","0","","st to st transf over CCIS"
"08","372","0","","alt route"
На другой:
"A701","0","00232","","OPC"
"A702","0","00228","","DPC"
"A704","0","00228","","---"
"A705","0","00228","","fault report"
"A8","00228","0","","CCIS routing label"
Были соединены: жел. оранж. (17) на жел. зел. (18),
оранж. жел. (42) на зел. жел. (43)
То есть как и положено прием на передачу, передачу на прием. При проверке потока светодиодом - он светится (то есть что-то все таки проходит).
В итоге на потоковой плате 30DTC нет никакой индикации: ни того что нет потока (то есть что-то он получает) и ни индикации нагрузки. И на SC00 Активность MTP тоже не горит. То есть поток так и не поднялся. Может кто подскажет где искать ошибку.
 Заголовок сообщения: Re: Не поднимается поток E1
СообщениеДобавлено: 21 окт 2014, 13:07
Если на карте потока нет аварийной индикации, значит поток как раз поднялся (конечно, если RUN мигает).
Что такое MTP - для меня загадка, но если мигает RUN и НЕ ГОРИТ LC, значит, не поднялся C-канал, что подтверждается и отсутствием индикации занятости на 30DTC.
Прежде чем погружаться в изучение чужих скриптов, хотелось бы прояснить:
Открыта ли лицензия CCIS на каждой из АТС.
Какой номер прошивки на ПЗУ платы SC00.
СообщениеДобавлено: 21 окт 2014, 17:17
RUN мигает. "Активность MTP" так написано в презентации по Neax 2000 IPS, то есть на плате SC00 есть два светодиода в центре, так это написано про верхний. И как я понимаю при нормальной индикации он должен гореть зеленым цветом. Как узнать открыта лицензия CCIS на АТС? Я думаю все же открыта. Потому что у нас 8 АТС с такими потоками уже стоит. И как узнать версию прошивки SC00?
СообщениеДобавлено: 21 окт 2014, 19:14
Гореть обязан. Кроме того должен мигать нижний светодиод красным на карте потока.
Ни о чем не говорит. В каждом процессоре свои лицензии. В теории - может и не быть.
Если через MATWorX, то закладка Upgrade -> SetKeyFD -> The Reference of KeyFD... -> Next
Если через команды, то F89 > 03
По надписи на самой карте (справа в нижней части карты бумажный лэйбл)
СообщениеДобавлено: 22 окт 2014, 06:22
Посмотрел есть ли лицензия на CCIS. При вводе вышесказанных команд - лицензия есть. На обоих процессорах:
PBX: CCIS/FCCS Opt, ISDN/I-term Opt, 512-port Basic, MFC/Caller ID Opt.
По поводу версий: на одной плате SC2753 S/N: D5TAP01922, на другой - SC 2753 S/N: B9TMP56699.
Также пробовал делать заворот на самих платах - поток сам на себя видит. Все как и положено мигает нижний светодиод на потоковой плате и горит зеленый на SC00.
СообщениеДобавлено: 22 окт 2014, 06:59
Прошу прощения. Нашел причину - на одной плате SC00 SW1 не были переключены 1-5 в положение ON. Видать пропустил из-за невнимательности. Зато узнал где смотреть лицензию :) Спасибо всем, за ответы!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 17
