| Подключение к CISCO по PRI http://forum.technoforward.ru/viewtopic.php?f=3&t=2369 |
| Автор: | mazandrey [ 21 янв 2014, 16:28 ] |
| Заголовок сообщения: | Подключение к CISCO по PRI |
Здравствуйте, не могу подключить 2000IPS SC-3655N1-0003.00 M-SITE, (лицензии установлены) к СISCO 2801. Карта потока PN-DTA установлена в 12 слот 0 PIM. При вллючении петли (переключателем) на карте загорается зеленый огонек D-канала. Команды настройки станции во вложении. Со стороны СИСКО: eburg-cise1#show isdn stat Global ISDN Switchtype = primary-net5 ISDN Serial0/1/0:15 interface ******* Network side configuration ******* dsl 0, interface ISDN Switchtype = primary-net5 Layer 1 Status: ACTIVE Layer 2 Status: TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0xFFFF7FFF Number of L2 Discards = 0, L2 Session ID = 66 Total Allocated ISDN CCBs = 0 eburg-cise1#show controllers e1 E1 0/1/0 is up. Applique type is Channelized E1 - balanced No alarms detected. alarm-trigger is not set Version info Firmware: 20090113, FPGA: 20, spm_count = 0 Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. CRC Threshold is 320. Reported from firmware is 320. Data in current interval (471 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs Total Data (last 24 hours) 0 Line Code Violations, 0 Path Code Violations, 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins, 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs eburg-cise1#show int ser 0/1/0:15 Serial0/1/0:15 is up, line protocol is up (spoofing) Hardware is DSX1 MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 459451 packets input, 1378957 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 8 input errors, 6 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort 460402 packets output, 1382214 bytes, 0 underruns 0 output errors, 0 collisions, 4 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags Все вроде бы в порядке, но когда все работает, то ЦИСКА должна писать TEL_ASSIGNED а она пишет MULTIPLE_FRAME_ESTABLISHED хотя в мануале это значение так же допустимо при норпмальной работе. Пожалуйста проверьте команды из файла во вложении, может где-то я перемудрил. С уважением Мазница Андрей. |
| Автор: | Shturmovik [ 28 янв 2014, 12:18 ] |
| Заголовок сообщения: | Re: Подключение к CISCO по PRI |
MULTIPLE_FRAME_ESTABLISHED это радость, TEL_ASSIGNED это полугрусть, DEACTIVATED ваще слезы. Поэтому, Андрей, не вижу вашей проблемы. |
| Автор: | Shturmovik [ 25 мар 2014, 07:53 ] |
Коллеги, прошу помощи. Подключение Cisco 1751v с Nec 2000 (с локальной нумерацией 66хх) по PRI. Маршрутизатор используется как VoIP шлюз для звонков на удаленные станции (одна из них 10хх). В станции установлены платы PN-SC01 (RSW=4) и PN-30DTC-C (RSW=5). В маршрутизаторе стоит VWIC-2MFT-E1. Настройки совершенно стандартные. Со стороны станции: 050 04 12 0701 0501 D101 ... 0701 0531 D131 482 04 0 482 05 1 AA15 04 0 AA15 05 0 AA00 04 0 AA00 05 0 AA06 04 24 AA06 05 24 AA14 04 1 AA14 05 1 3000 101 50 ... 3000 115 50 3000 116 51 3000 117 50 ... 3000 131 50 3002 101 18 ... 3002 115 18 3002 116 31 3002 117 18 ... 3002 131 18 3007 101 000 ... 3007 115 014 3007 117 015 ... 3007 131 029 3500 50 00 3500 51 15 3502 50 3 3504 50 2 3504 51 7 3505 50 1 3509 50 08 3509 51 15 3511 50 3 3514 50 1 3515 50 none 3516 50 0 3528 50 0 3539 50 1 3589 50 1 3589 51 1 3590 50 3 3590 51 3 35130 50 0 A900 0 116 200 66 804 200 10 A129 8AA000 3 4005 8A4005 10 0050 8A0050 1 00050 Со стороны маршрутизатора: tdm clock E1 1/0 both export line tdm clock E1 1/1 both import E1 1/0 internal voice-card 1 isdn switch-type primary-net5 controller E1 1/0 framing NO-CRC4 pri-group timeslots 1-16 controller E1 1/1 shutdown interface FastEthernet0/0 description to LAN ip address 10.200.56.120 255.255.255.0 load-interval 30 speed auto full-duplex no cdp enable h323-gateway voip interface h323-gateway voip bind srcaddr 10.200.56.120 interface Serial1/0:15 no ip address encapsulation hdlc no logging event link-status isdn switch-type primary-net5 isdn protocol-emulate network isdn incoming-voice voice isdn bchan-number-order ascending round-robin no cdp enable voice-port 1/0:15 cptone RU bearer-cap 3100Hz dial-peer cor custom dial-peer voice 1 pots destination-pattern 66..$ direct-inward-dial port 1/0:15 forward-digits all dial-peer voice 10 voip destination-pattern 10..$ session target ipv4:10.66.254.254 fax rate 7200 fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback cisco ip qos dscp cs5 media Теперь о проблемах: tereshk-1751v#sh isdn sta Global ISDN Switchtype = primary-net5 ISDN Serial1/0:15 interface ******* Network side configuration ******* dsl 0, interface ISDN Switchtype = primary-net5 Layer 1 Status: ACTIVE Layer 2 Status: TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0x80007FFF Number of L2 Discards = 0, L2 Session ID = 183 Total Allocated ISDN CCBs = 0 tereshk-1751v# Jan 23 18:10:50.828: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3 Jan 23 18:10:50.832: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3 Jan 23 18:11:00.596: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3 Jan 23 18:11:00.596: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3 Jan 23 18:11:10.364: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3 Jan 23 18:11:10.364: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3 Тут вроде все нормально. Но когда со станции делаю звонок на удаленную АТС на номера 10хх, то на маршрутизаторе никакой активности. Если с маршрутизатора делаю тестовый звонок на удаленную АТС на номера 10хх, то он проходит: tereshk-1751v#csim start 1011 csim: called number = 1011, loop count = 1 ping count = 0 csim err csimDisconnected recvd DISC cid(19) csim info: cid(19), state(1), cause(16) csim: loop = 1, failed = 1 csim: call attempted = 1, setup failed = 1, tone failed = 0 Если делаю звонок с маршрутизатора на соединенную станцию на номера 66хх, то звонок не проходит и выдает следующее: tereshk-1751v#csim start 6601 csim: called number = 6601, loop count = 1 ping count = 0 csim err csimDisconnected recvd DISC cid(20) csim info: cid(20), state(0), cause(82) csim: loop = 1, failed = 1 csim: call attempted = 1, setup failed = 1, tone failed = 0 tereshk-1751v# Jan 23 18:21:57.214: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0082 Bearer Capability i = 0x9090A3 Standard = CCITT Transfer Capability = 3.1kHz Audio Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA98384 Exclusive, Channel 4 Called Party Number i = 0x80, '6601' Plan:Unknown, Type:Unknown Jan 23 18:21:57.370: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x 8082 Cause i = 0x81D2 - Identified channel does not exist Прошу помощи! |
| Автор: | Shturmovik [ 01 апр 2014, 10:46 ] |
ап |
| Автор: | Shturmovik [ 21 апр 2014, 19:08 ] |
еще раз ап |
