Текущее время: 24 окт 2026, 21:42
 Заголовок сообщения: Подключение к CISCO по PRI
СообщениеДобавлено: 21 янв 2014, 16:28
Здравствуйте, не могу подключить 2000IPS SC-3655N1-0003.00 M-SITE, (лицензии установлены) к СISCO 2801. Карта потока PN-DTA установлена в 12 слот 0 PIM. При вллючении петли (переключателем) на карте загорается зеленый огонек D-канала. Команды настройки станции во вложении.
Со стороны СИСКО:
eburg-cise1#show isdn stat
Global ISDN Switchtype = primary-net5
ISDN Serial0/1/0:15 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 66
Total Allocated ISDN CCBs = 0
eburg-cise1#show controllers e1
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20090113, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (471 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
eburg-cise1#show int ser 0/1/0:15
Serial0/1/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation HDLC, loopback not set
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
459451 packets input, 1378957 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
8 input errors, 6 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort
460402 packets output, 1382214 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 output buffer failures, 0 output buffers swapped out
1 carrier transitions
Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
Все вроде бы в порядке, но когда все работает, то ЦИСКА должна писать TEL_ASSIGNED а она пишет MULTIPLE_FRAME_ESTABLISHED хотя в мануале это значение так же допустимо при норпмальной работе.
Пожалуйста проверьте команды из файла во вложении, может где-то я перемудрил.
С уважением
Мазница Андрей.
 Заголовок сообщения: Re: Подключение к CISCO по PRI
СообщениеДобавлено: 28 янв 2014, 12:18
MULTIPLE_FRAME_ESTABLISHED это радость,
TEL_ASSIGNED это полугрусть,
DEACTIVATED ваще слезы.
Поэтому, Андрей, не вижу вашей проблемы.
СообщениеДобавлено: 25 мар 2014, 07:53
Коллеги, прошу помощи.
Подключение Cisco 1751v с Nec 2000 (с локальной нумерацией 66хх) по PRI.
Маршрутизатор используется как VoIP шлюз для звонков на удаленные станции (одна из них 10хх).
В станции установлены платы PN-SC01 (RSW=4) и PN-30DTC-C (RSW=5).
В маршрутизаторе стоит VWIC-2MFT-E1.
Настройки совершенно стандартные.
Со стороны станции:
050 04 12
0701 0501 D101
0701 0531 D131
482 04 0
482 05 1
AA15 04 0
AA15 05 0
AA00 04 0
AA00 05 0
AA06 04 24
AA06 05 24
AA14 04 1
AA14 05 1
3000 101 50
3000 115 50
3000 116 51
3000 117 50
3000 131 50
3002 101 18
3002 115 18
3002 116 31
3002 117 18
3002 131 18
3007 101 000
3007 115 014
3007 117 015
3007 131 029
3500 50 00
3500 51 15
3502 50 3
3504 50 2
3504 51 7
3505 50 1
3509 50 08
3509 51 15
3511 50 3
3514 50 1
3515 50 none
3516 50 0
3528 50 0
3539 50 1
3589 50 1
3589 51 1
3590 50 3
3590 51 3
35130 50 0
A900 0 116
200 66 804
200 10 A129
8AA000 3 4005
8A4005 10 0050
8A0050 1 00050
Со стороны маршрутизатора:
tdm clock E1 1/0 both export line
tdm clock E1 1/1 both import E1 1/0 internal
voice-card 1
isdn switch-type primary-net5
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-16
controller E1 1/1
shutdown
interface FastEthernet0/0
description to LAN
ip address 10.200.56.120 255.255.255.0
load-interval 30
speed auto
full-duplex
no cdp enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.200.56.120
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn protocol-emulate network
isdn incoming-voice voice
isdn bchan-number-order ascending round-robin
no cdp enable
voice-port 1/0:15
cptone RU
bearer-cap 3100Hz
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 66..$
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 10 voip
destination-pattern 10..$
session target ipv4:10.66.254.254
fax rate 7200
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback cisco
ip qos dscp cs5 media
Теперь о проблемах:
tereshk-1751v#sh isdn sta
ISDN Serial1/0:15 interface
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
The Free Channel Mask: 0x80007FFF
Number of L2 Discards = 0, L2 Session ID = 183
tereshk-1751v#
Jan 23 18:10:50.828: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3
Jan 23 18:10:50.832: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3
Jan 23 18:11:00.596: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3
Jan 23 18:11:00.596: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3
Jan 23 18:11:10.364: ISDN Se1/0:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=3
Jan 23 18:11:10.364: ISDN Se1/0:15 Q921: Net TX -> RRf sapi=0 tei=0 nr=3
Тут вроде все нормально.
Но когда со станции делаю звонок на удаленную АТС на номера 10хх, то на маршрутизаторе никакой активности.
Если с маршрутизатора делаю тестовый звонок на удаленную АТС на номера 10хх, то он проходит:
tereshk-1751v#csim start 1011
csim: called number = 1011, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(19)
csim info: cid(19), state(1), cause(16)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Если делаю звонок с маршрутизатора на соединенную станцию на номера 66хх, то звонок не проходит и выдает следующее:
tereshk-1751v#csim start 6601
csim: called number = 6601, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(20)
csim info: cid(20), state(0), cause(82)
tereshk-1751v#
Jan 23 18:21:57.214: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0082
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98384
Exclusive, Channel 4
Called Party Number i = 0x80, '6601'
Plan:Unknown, Type:Unknown
Jan 23 18:21:57.370: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
8082
Cause i = 0x81D2 - Identified channel does not exist
Прошу помощи!
СообщениеДобавлено: 01 апр 2014, 10:46
ап
СообщениеДобавлено: 21 апр 2014, 19:08
еще раз ап
