| SIP СЛ http://forum.technoforward.ru/viewtopic.php?f=27&t=3115 |
| Автор: | dimonchik [ 10 окт 2016, 14:38 ] |
| Заголовок сообщения: | SIP СЛ |
Добрый день, подскажите пожалуйста следующий вопрос, есть 32 SIP СЛ со следующими настройками: CM10 - YY=03 - 000 D032 ... 031 D063 - добавление SIP СЛ CM0B - YY=1-01+50 - 53 - 1(Def.)Not Available CM30 - 00 - 03 D032 ... D062 Trunk Rout CM30 - 00 - 04 D063 Trunk Rout CM30 - 02 - 31 (Def.) : DID, Tie Line and the call which is not handled by the PBX CM30 - 03 - 231 (Def.) : DID, Tie Line and the call which is not handled by the PBX CM30 - 35 - D032 ... D062 CIC 032 ... 062 CM35 - 009 - 03 Trunk Rout 03 : Wink Start/CCIS/SIP CM35 - 000 - 03 Trunk Rout 04 : TIE(Tie line)trunk CM35 - 090 - 03 Trunk Rout 0 : No 7 CCIS, SIP trunk CM35 - 091 - 03 Trunk Rout 03:03 CCH CM35 - 004 - 03 Trunk Rout 2 : Answer signal arrives (Tie line/ISDN/CCIS/SIP) CM35 - 020 - 03 Trunk Rout 00 : Wink Start/CCIS/SIP CM35 - 134 - 03 Trunk Rout 05:05 : PRECEDENCE CM41 - Y=0 134 : 33:33 second CMA7 - 00 : 063 - COMMON CHANEL SIGNALING HANDLE 03 CMA7 - 46 - 0: Point-to-Multipoint - COMMON CHANEL SIGNALING HANDLE 03 CMA7 - 01 - Original Point Code 00001 - COMMON CHANEL SIGNALING HANDLE 03 CMA7 - 02 - Destination Point Code 00002 - COMMON CHANEL SIGNALING HANDLE 03 CMA7 - 71 Sip Profile 05:05 - COMMON CHANEL SIGNALING HANDLE 03 CM8A - TR/LCR Pattern 5001 - 157 - 03 Normal Local Call... CM8A - TR/LCR Pattern 5001 - 167 - 000:000 IP Addres Pattern CM8A - TR/LCR Pattern 5001 - 168 - 00002 DPC CM8A - TR/LCR Pattern 5001 - 179 - 05:05 Profile number CM5B - IP Addres Pattern - 000 IP Addres - 00 - 01 : 192168100204 Destination IP Addres for SIP trunk Сама маршрутизация: CM20 - Набираемые цифра 2 - A126 CM35 - 076 - 03 Trunk Rout - 03:03 Area Code Development Pattern No CM8A - AXXX - LCR Group 0 - Area Code Development Pattern No 4003:3 CM8A - 4XXX - Area Code 0 - Area Code Development Pattern No 4003 - 0003 : Route Pattern 003 CM8A - 0XXX - Route Pattern No 0003 - Next Pattern : 0000:000 - TR/LCR Pattern : 001:001 - Trunk Route 03:03 CM8A - 1XXX - 1000 : Tenant Pattern No : 00 - Route Pattern : 0003 : 003 CM8A - 5XXX - 100 - Digit Addition Pattern No : 9000:000 CM8A - 9XXX - Digit Addition Pattern No : 9000 - Digits to be Added : 20 По идее должно быть 32 одновременных вызова по этим 32 SIP СЛ, но по факту работает только 31, 32-ой выдает занято... Подскажите пожалуйста, где может быть ошибка? |
| Автор: | NEAXMAN [ 10 окт 2016, 14:53 ] |
| Заголовок сообщения: | Re: SIP СЛ |
Цитата: CM30 - 00 - 03 D032 ... D062 Trunk Rout Здесь, во всяком случае, в рут записан 31 транк...
| Автор: | dimonchik [ 13 окт 2016, 13:59 ] |
спасибо, помогло |
