Текущее время: 25 ноя 2026, 05:16
 Заголовок сообщения: SIP СЛ
СообщениеДобавлено: 10 окт 2016, 14:38
Добрый день, подскажите пожалуйста следующий вопрос, есть 32 SIP СЛ со следующими настройками:
CM10 - YY=03 - 000 D032 ... 031 D063 - добавление SIP СЛ
CM0B - YY=1-01+50 - 53 - 1(Def.)Not Available
CM30 - 00 - 03 D032 ... D062 Trunk Rout
CM30 - 00 - 04 D063 Trunk Rout
CM30 - 02 - 31 (Def.) : DID, Tie Line and the call which is not handled by the PBX
CM30 - 03 - 231 (Def.) : DID, Tie Line and the call which is not handled by the PBX
CM30 - 35 - D032 ... D062 CIC 032 ... 062
CM35 - 009 - 03 Trunk Rout 03 : Wink Start/CCIS/SIP
CM35 - 000 - 03 Trunk Rout 04 : TIE(Tie line)trunk
CM35 - 090 - 03 Trunk Rout 0 : No 7 CCIS, SIP trunk
CM35 - 091 - 03 Trunk Rout 03:03 CCH
CM35 - 004 - 03 Trunk Rout 2 : Answer signal arrives (Tie line/ISDN/CCIS/SIP)
CM35 - 020 - 03 Trunk Rout 00 : Wink Start/CCIS/SIP
CM35 - 134 - 03 Trunk Rout 05:05 : PRECEDENCE
CM41 - Y=0 134 : 33:33 second
CMA7 - 00 : 063 - COMMON CHANEL SIGNALING HANDLE 03
CMA7 - 46 - 0: Point-to-Multipoint - COMMON CHANEL SIGNALING HANDLE 03
CMA7 - 01 - Original Point Code 00001 - COMMON CHANEL SIGNALING HANDLE 03
CMA7 - 02 - Destination Point Code 00002 - COMMON CHANEL SIGNALING HANDLE 03
CMA7 - 71 Sip Profile 05:05 - COMMON CHANEL SIGNALING HANDLE 03
CM8A - TR/LCR Pattern 5001 - 157 - 03 Normal Local Call...
CM8A - TR/LCR Pattern 5001 - 167 - 000:000 IP Addres Pattern
CM8A - TR/LCR Pattern 5001 - 168 - 00002 DPC
CM8A - TR/LCR Pattern 5001 - 179 - 05:05 Profile number
CM5B - IP Addres Pattern - 000 IP Addres - 00 - 01 : 192168100204 Destination IP Addres for SIP trunk
Сама маршрутизация:
CM20 - Набираемые цифра 2 - A126
CM35 - 076 - 03 Trunk Rout - 03:03 Area Code Development Pattern No
CM8A - AXXX - LCR Group 0 - Area Code Development Pattern No 4003:3
CM8A - 4XXX - Area Code 0 - Area Code Development Pattern No 4003 - 0003 : Route Pattern 003
CM8A - 0XXX - Route Pattern No 0003 - Next Pattern : 0000:000 - TR/LCR Pattern : 001:001 - Trunk Route 03:03
CM8A - 1XXX - 1000 : Tenant Pattern No : 00 - Route Pattern : 0003 : 003
CM8A - 5XXX - 100 - Digit Addition Pattern No : 9000:000
CM8A - 9XXX - Digit Addition Pattern No : 9000 - Digits to be Added : 20
По идее должно быть 32 одновременных вызова по этим 32 SIP СЛ, но по факту работает только 31, 32-ой выдает занято... Подскажите пожалуйста, где может быть ошибка?
 Заголовок сообщения: Re: SIP СЛ
СообщениеДобавлено: 10 окт 2016, 14:53
Здесь, во всяком случае, в рут записан 31 транк...
СообщениеДобавлено: 13 окт 2016, 13:59
спасибо, помогло
