| соединение 3-х станций по ССIS http://forum.technoforward.ru/viewtopic.php?f=24&t=1711 |
| Автор: | paul [ 30 янв 2012, 11:51 ] |
| Заголовок сообщения: | соединение 3-х станций по ССIS |
Приветствую уважаемые форумчане! Столкнулся с проблемой - надо объединить 3 станции sv8300 по ccis Две из них уже работают - настройки привожу ниже Третью станцию настраиваю аналогично - в результате звонок проходит только с третьей станции на первую и все. Настройки 1 станции: 1002,"000","D000","","" 1002,"001","D001","","" 1002,"002","D002","","" 1002,"003","D003","","" 1002,"004","D004","","" 1002,"005","D005","","" 1002,"006","D006","","" 1002,"007","D007","","" 1002,"008","D008","","" 1002,"009","D009","","" 1002,"010","D010","","" 1002,"011","D011","","" 1002,"012","D012","","" 1002,"013","D013","","" 1002,"014","D014","","" 1002,"015","D015","","" 1002,"016","D016","","" 1002,"017","D017","","" 1002,"018","D018","","" 1002,"019","D019","","" 1002,"020","D020","","" 1002,"021","D021","","" 1002,"022","D022","","" 1002,"023","D023","","" 1002,"024","D024","","" 1002,"025","D025","","" 1002,"026","D026","","" 1002,"027","D027","","" 1002,"028","D028","","" 1002,"029","D029","","" 1002,"030","D030","","" 1002,"031","D031","","" 1002,"032","D032","","" 1002,"033","D033","","" 1002,"034","D034","","" 1002,"035","D035","","" 1002,"036","D036","","" 1002,"037","D037","","" 1002,"038","D038","","" 1002,"039","D039","","" 1002,"040","D040","","" 1002,"041","D041","","" 1002,"042","D042","","" 1002,"043","D043","","" 1002,"044","D044","","" 1002,"045","D045","","" 1002,"046","D046","","" 1002,"047","D047","","" 1002,"048","D048","","" 1002,"049","D049","","" 1002,"050","D050","","" 1002,"051","D051","","" 1002,"052","D052","","" 1002,"053","D053","","" 1002,"054","D054","","" 1002,"055","D055","","" 1002,"056","D056","","" 1002,"057","D057","","" 1002,"058","D058","","" 1002,"059","D059","","" 1002,"060","D060","","" 1002,"061","D061","","" 1002,"062","D062","","" 1002,"063","D063","","" 1002,"064","D064","","" 1002,"065","D065","","" 1002,"066","D066","","" 1002,"067","D067","","" 1002,"068","D068","","" 1002,"069","D069","","" 1002,"070","D070","","" 1002,"071","D071","","" 1002,"072","D072","","" 1002,"073","D073","","" 1002,"074","D074","","" 1002,"075","D075","","" 1002,"076","D076","","" 1002,"077","D077","","" 1002,"078","D078","","" 1002,"079","D079","","" 1002,"080","D080","","" 1002,"081","D081","","" 1002,"082","D082","","" 1002,"083","D083","","" 1002,"084","D084","","" 1002,"085","D085","","" 1002,"086","D086","","" 1002,"087","D087","","" 1002,"088","D088","","" 1002,"089","D089","","" 1002,"090","D090","","" 3000,"001","00","","" 3000,"002","00","","" 3000,"003","00","","" 3000,"004","00","","" 3000,"005","00","","" 3000,"006","00","","" 3000,"007","00","","" 3000,"008","00","","" 3000,"009","00","","" 3000,"010","00","","" 3000,"011","00","","" 3000,"012","00","","" 3000,"013","00","","" 3000,"014","00","","" 3000,"015","00","","" 3000,"016","00","","" 3000,"017","00","","" 3000,"018","00","","" 3000,"019","00","","" 3000,"020","00","","" 3000,"021","00","","" 3000,"022","00","","" 3000,"023","00","","" 3000,"024","00","","" 3000,"025","00","","" 3000,"026","00","","" 3000,"027","00","","" 3000,"028","00","","" 3000,"029","00","","" 3000,"030","00","","" 3000,"031","00","","" 3000,"032","00","","" 3000,"033","00","","" 3000,"034","00","","" 3000,"035","00","","" 3000,"036","00","","" 3000,"037","00","","" 3000,"038","00","","" 3000,"039","00","","" 3000,"040","00","","" 3000,"041","00","","" 3000,"042","00","","" 3000,"043","00","","" 3000,"044","00","","" 3000,"045","00","","" 3000,"046","00","","" 3000,"047","00","","" 3000,"048","00","","" 3000,"049","00","","" 3000,"050","00","","" 3000,"051","00","","" 3000,"052","00","","" 3000,"053","00","","" 3000,"054","00","","" 3000,"055","00","","" 3000,"056","00","","" 3000,"057","00","","" 3000,"058","00","","" 3000,"059","00","","" 3000,"060","00","","" 3000,"061","00","","" 3000,"062","00","","" 3000,"063","00","","" 3000,"064","00","","" 3000,"065","00","","" 3000,"066","00","","" 3000,"067","00","","" 3000,"068","00","","" 3000,"069","00","","" 3000,"070","00","","" 3000,"071","00","","" 3000,"072","00","","" 3000,"073","00","","" 3000,"074","00","","" 3000,"075","00","","" 3000,"076","00","","" 3000,"077","00","","" 3000,"078","00","","" 3000,"079","00","","" 3000,"080","00","","" 3000,"081","00","","" 3000,"082","00","","" 3000,"083","00","","" 3000,"084","00","","" 3000,"085","00","","" 3000,"086","00","","" 3000,"087","00","","" 3000,"088","00","","" 3000,"089","00","","" 3000,"090","00","","" 35000,"00","04","","" 35004,"00","2","","" 35005,"00","1","","" 35009,"00","03","","" 35020,"00","00","","" 35083,"00","0","","" 35090,"00","0","","" 35091,"00","00","","" A700,"00","000","","" A701,"00","00001","","" A746,"00","0","","" A726,"00","0","","" A728,"00","0","","" A80,"00002","00","","" A81,"00002","010000119038","","" |
| Автор: | NEAXMAN [ 31 янв 2012, 08:58 ] |
| Заголовок сообщения: | Re: соединение 3-х станций по ССIS |
Если хоть какие-то вызовы хоть куда-то проходят, то назначения 30-й 35-й и иже с ними команд, относящиеся к физике стыков, интереса, скорее всего, не представляют. Проблема, видимо, в назначениях, описывающих топологию сети - пойнт-коды (А7-е команды), адресацию сообщений на С-хендлеры (A8), нумерационный план (20), LCR (8A). Причем, при интеграции нового узла в действующую сеть требуются усилия в этом направлении не только в новом, но и в действующих узлах. Думаю, имеет смысл внимательно посмотреть раздел NETWORK STRUCTURE CONSIDERATIONS главы 1 CCIS FEATURES в Networking Manual (CCIS, QSig, Remote unit). |
| Автор: | SKA_zo4nik [ 30 авг 2012, 14:12 ] |
Вопрос такой, а в стыковой станции необходимо делать 2 роута, и свои транки в свой роут? и соответственно два IP транка? или все пускать в 00? а разруливается уже в 200 по DPC? разобрался)) |
